I am trying to color edges (border and interior) of a planar shape layer (see screenshot) in CE using CGA. Ultimately, it would be great if colors could be chosen for the background (faces?) color as well as the outlines (edges?). I have been looking into the comp(Operation) option to select out the edges and color them. If I use:
set(material.opacity, Transparency)
color (...)
...then I can change the color/transparency of the entire shape, but the individual shape outlines are not visible and do not have a distinct color when I export the models as .3ws. I would like to be able to designate colors for both the outline and shape in CE prior to the export. Any suggestions would be very helpful as I am new to CE/CGA.
I have attached my current CGA code as well as a snip of the layer I am working with.
Thanks!
version "2015.1"
attr Fill_Color = "#FFFFF"
attr Outline_Color = "#000000"
attr Transparency = 0.9
@StartRule
Shape -->
comp(e) {all: color(Outline_Color)
comp(f) {all: color(Fill_Color)
X.
Solved! Go to Solution.
Okay, I just fixed on it for a minute. I simplified it to be more readable. Now you have a start rule, and that rule sends the border to a new rule, and the inside shape to a new rule. Just easier to read/debug that way. Face clashing effect should be gone now. I also reversed the set opacity part, so that increasing that attribute increases the transparency (since opacity is the opposite of transparency):
set(material.opacity, 1-Transparency)
CGA file is attached.
Chris
Try using the CGA operation called offset, together with comp. Send individual faces to a rule like this:
AddOutline -->
offset(-0.02) # thickness of your border. Negative value offsets inwards.
comp( f ) {border: color(myBorderColor) MyBorder. | inside: MyInside.}
Chris
Thank you so much for your help! I was able to get the outlines using:
version "2015.1"
attr Fill_Color = "#FFF80"
@StartRule
AddOutline -->
offset(-0.5) # thickness of your border. Negative value offsets inwards.
comp( f ) {border: color(Outline_Color) MyBorder. | inside: MyInside.}
Shape -->
color(Fill_Color)
X.
Any ideas on how to get the fill color to show up?
Thanks again,
Tess
This line has a couple of placeholders:
Your rule called Shape is not getting called anywhere, so use the "inside" selector to run your rule "Shape" from there....
comp( f ) {border: color(Outline_Color) MyBorder. | inside: Shape}
That seems to do the trick. Thanks a ton!
The fill color is just patchy.... It shows up the same way in the WebScene too.
Might be another copy of the floor faces. You want to post the rule? I'll check it over if so.
Absolutely. Thanks!
version "2015.1"
@StartRule
AddOutline -->
offset(-0.2) # thickness of your border. Negative value offsets inwards.
comp( f ) {border: color(Outline_Color) MyBorder. | inside: Shape.}
color(Fill_Color)
X.
Chris
Chris,
It looks a ton better now. Thank you so much for all of your help and time!
Tess
