I have a project from 2014 that exists as a CityEngine WebScene (.3ws). I haven't used CityEngine in a while, and we just discovered this platform has been retired and the project no longer works. I have been trying to figure out how to rescue this content.
- What is the best alternative format (such as a Scene Layer Package)?
- Is there a way to directly convert the file or will I have to rebuild and re-export?
- It appears that some of the features no longer available (i.e. interacting with the rule parameters, using sliders between layers, etc)?
- Is there any possible way to still view the original 3ws models?
Thank you!
Solved! Go to Solution.
Hi Marie,
Best,
Simon
Hi Marie,
Best,
Simon
Thanks Simon, this answers my initial questions.
For the purposes of archiving/documenting this academic project, do you have any suggestions on how to obtain an older version of the software? I currently only have access to 2023.0.
Also, is it possible to set up a local server to make the project available publicly as a webscene? I still run into CityEngine webscenes on the internet but I'm not sure how they are set up.
Thanks for your help.
Marie
You should have access to CityEngine 2022.1 in your MyEsri account. If you do not see 2022.1, feel free to send me your Esri customer number in a direct message so I can forward this to our customer service.
The viewer included in 2022.1 is fully self-contained, i.e. you should be able to extract it and put it on a web server. Please note that this is not anymore a supported product, i.e. there might be functional limitations as well as security issues.
Best,
Simon
