Creating a 3D boundary...What's the best way to create a 3D boundary from a shapefile?
4802
10
02-24-2015 08:32 AM
MichaelWalton
New Contributor III
NOTE: I don't have the feature to line or polygon to line tool licensed for ArcGIS analysis.
So, I have a polygon shapefile in CityEngine and I want it to be a thin 3D outline with no color infill. I tried doing it in ArcGIS Pro by setting the symbology properties and extruding. I do not like the way it looks see image...Boundary.JPG
Also I don't want it in Pro anyway...I'd like to write a CE rule that turns this boundary shapefile into a 3D tube. Any ideas for how I can write this rule?
by Anonymous User
Not applicable
Here's what happens at the corners (automatic miter cut):
by Anonymous User
Not applicable
This works in most cases (strange shapes work better with smaller pipe diameter):
attr pipeThickness = 5
@StartRule
Boundary -->
  offset(-pipeThickness) comp(f) {inside: Inside}
Inside -->
  extrude(pipeThickness) comp(f) {side: Pipeline}
Pipeline -->
  s('20,'1,'1)
  center(x)
  i("assets/pipe.obj")
# Asset is attached.
# Let me know if this works, Chris
by Anonymous User
Not applicable
MichaelWalton
New Contributor III
Thank you,
It works nicely for me.
MichaelWalton
New Contributor III
Hi Chris,
I was told that the 3D boundary looks too much like an oil pipeline, so I am trying to make it into a dashed 3D line...But CityEngine keeps crashing as I update the code....Can you please test this code out to see if it works?
attr pipeThickness = 1.5
attr colorer = "#ffffff"
@StartRule
Boundary -->
Inside -->
Pipeline -->
  s('5,'1,'1)
  center(x)
  i("models/pipe/pipe.obj")
  t(0,'0.5,0)
  split(x) { { ~5 : Pipeline | ~1 : NIL }*  | ~5 : Pipeline }
  color(colorer)
by Anonymous User
Not applicable
Michael,
This is crashing due to an endless loop. The Pipeline rule is calling itself. It is fine for a rule to call itself, but there must be an exit condition (that is called recursion and is quite useful in CGA).
I just changed this line:
split(x) { { ~0.75 : Pipeline | ~1 : NIL }*  | ~0.75 : Pipeline }
To this (has period after the word Pipeline):
split(x) { { ~0.75 : Pipeline. | ~1 : NIL }*  | ~0.75 : Pipeline. }
Or this:
split(x) { { ~0.75 : ThisIsAFinalShapeSoItHasAPeriodAfterIt. | ~1 : NIL }*  | ~0.75 : ThisIsAFinalShapeSoItHasAPeriodAfterIt. }
And I can see this (looks good except the last pipe parts have a face dropped):
by Anonymous User
Not applicable
Michael,
I looked at the corner thing and wasn't sure if you wanted the empty corners. If you do, then here is a modification to do that. Also moved the color command to the very first line, just to execute it only once.
attr cornerScale = 1  # Make this higher number to handle sharp corners.
@StartRule
Boundary -->
  color(colorer)
Inside -->
Pipeline -->
  s('20,'1,'1)  # Added this for automatic trim.
  center(x)
  t(0,'0.5,0)
  i("pipe.obj")
  split(x) {
    ~(pipeThickness * cornerScale) : PipeCorner. | # Longer to handle corners.
    {~(pipeThickness * 2/3) : NIL | ~(pipeThickness * 0.5) : PipeDash. }* |
    ~(pipeThickness * cornerScale) : PipeCorner.   # Longer to handle corners.
MichaelWalton
New Contributor III
The rule works when displayed in the cga rule preview window...
However, when assigning the dashed boundary rule to an irregular shapefile, it causes a big long crash to any computer. If I draw a perfect rectangle, the rule works perfectly. But, on the complex and irregular shapes there is a big problem. I tried to increase the  corner scale to 5 meters, but  it still crashed when applied to my district's political boundary.
MichaelWalton
New Contributor III
     For instance, the same rule applied to the shapefile looks different in some areas and corners.
        Good                                                  Bad                                                   Ugly
by Anonymous User
Not applicable
I did know that sharp corners would possibly break it. I'd have to see the project and shapes in question to help trouble shoot. I'm a bit knee deep this morning, but if you can't fix it, try posting a stripped out version of the project, so that we can see and test on the same shapes you are using (scene, rules, assets).
Chris
