Exporting CityEngine model to Unity
1597
09-23-2021 11:26 AM
AnnaConway
Hello! I've been running into an issue where exporting my models renders them invisible in Unity. I have also tried to import the .fbx generated by CityEngine into Maya and it is invisible there too.
Not quite sure what is going wrong.
I'm using the "Building_From_Footprint.cga" for buildings that I have drawn shapes for and the "Complete_Street.cga" for the roads I have drawn as well. The buildings generated by the engine have a default rule applied when I got the map data.
I have followed the Esri page on how to export as well as this video with no luck. My scale in Unity is not the issue.
In Unity, I am receiving errors such as:
Next vertex not found in CheckWinding()
UnityEngine.GUIUtility:ProcessEvent (int,intptr,bool&)
And warnings such as:
Mesh 'CityEngineMaterial_6_m' has no normals. Recalculating normals.
A polygon of Mesh 'CityEngineMaterial_m' in Assets/DigiRoc/Roads/DigiRoc_0.fbx is self-intersecting and has been discarded.
ImportFBX Warnings:
Can't import normals, because mesh 'CityEngineMaterial_10_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_11_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_1_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_2_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_3_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_4_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_5_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_6_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_7_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_8_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_9_m' doesn't have any.
Can't import normals, because mesh 'CityEngineMaterial_m' doesn't have any.
Can't import normals, because mesh 'CityEngineShapeMaterial_m' doesn't have any.
Here is a screenshot of my project if it helps. There aren't many textures other than the sidewalks. Some of the more detailed models like that chapel were imported into CityeEngine by a 3D Modeler who hand-made them in Maya. Thank you!
AnnaConway
Also, aside from bumping, if anyone could point me in the direction of another resource that may help (another forum, community, etc) that'd be equally appreciated 🙂
by Anonymous User
Not applicable
I don't know if I can be much help on a technical question like this, but have you tried the cleanupGeometry rule when you import your "hand-made" Maya fbx models into your CityEngine scene/rule files?   That might help resolve some of the issues.
