filter cityengine graph/shape by attribute
1366
09-07-2017 04:49 AM
noamfarhi
hello everyone
is there any way i can filter or select objects by their attribute as similar to arc-map?
the search path is good for a simple selection like one attribute but can't handle selection by multiple attributes...
any answer will be helpful!
LR
You'll have to use Python, AFAIK. Look for ce.getObjectsFrom. Here's the command reference: Help -
CherylLau
You might be able to search for two attribute values by using separating the values with a space, but I don't think this is a reliable way of getting the desired search results.  Python is probably the way to go.  Check out this post:
https://community.esri.com/message/689542-re-layer-search
