Scene Layer ordering
1461
9
06-19-2017 05:52 AM
Luiz_AmadeuCoutinho
Occasional Contributor III
Hi
In CityEngine Scene Layers my layers are on the correct order, but when are exported to Webscene CityEngine put the layers randomly. There´s a mix of Static Models, Basemap, Shapes....
Maybe is a basic question but I don know how to fix it.
Tags (1)
CherylLau
That's strange.  I can't seem to reproduce it.  The layers are all in the correct order if I follow the steps to export the scene in Tutorial 15 (Help -> Download Tutorials and Examples).  Does this tutorial work for you?
Tutorial 15: Publish web scenes—CityEngine Tutorials | ArcGIS Desktop
I noticed that there's an asterix in the Scene tab which means that the scene has not been saved.  Does saving the scene help?  The exporter should export the scene with the changes even if the scene is not saved, but it would be interesting to know if this helps or not.
Luiz_AmadeuCoutinho
Hi Cheryl
I know it´s tottaly weird.
The scene was saved before export, but still doing the same . Check the prints, please. I´m not using any previous  export Settings. 😞
CherylLau
Did Tutorial 15 work for you?
I noticed you are using version 2015.2.  You could try upgrading to 2016.1, but I don't think it should make a difference in this case since exporting Tutorial 15 with 2015.2 also worked for me.
Luiz_AmadeuCoutinho
I did the Tutorial 15 and worked very well.
Crazy isn´t?
CherylLau
I can't see why this doesn't work.  Can you think of something that might be different about your scene compared to tutorial 15?  Would you be able to post your scene?
Luiz_AmadeuCoutinho
I´m trying to compare with Tutorial 15, I can´t see anything special.
Here my scene : http://bit.ly/2sSEu7n
Thank you for the support
CherylLau
Sorry, I meant the CityEngine project.
Luiz_AmadeuCoutinho
Hi Cheryl
I can´t share the project.
Luiz_AmadeuCoutinho
I found one "solution" .
My Cityengine was upgraded to 2016.1
Solution: Create a new project and import the layers and models ordering the first(the layer that you want to show on top of the webscene) to the last.
I mean:
Addind to ViewPort
Layer 1
Layer 2
Layer 3...
Basemap(the last one)
and publish.
On export models per layer will show the sequencial order that you added(The older first-Layer 1 and the newer last - Basemap).
The problem: If I want to change the order again I must to create a new project and restart the process.
Here my new Webscene updated: http://bit.ly/2toSd5U
