ArcGIS Collector Blog
89
1.9M
41
The functionality of ArcGIS Collector is now available in ArcGIS Field Maps. While existing ideas may be considered
for ArcGIS Field Maps, please submit new Collector ideas in the ArcGIS Field Maps idea exchange.
Under Consideration | Currently the deprecation item flag is mostly useless. It can be a deterrent from new users picking a service but the... by stevegourley Occasional Contributor II 9 2 | 9 | 2 | |
Under Consideration | Please implement the ability to snap to a feature edge without requiring a vertex in the Field Maps app. I would reco... by JustinRay1 Occasional Contributor 14 4 | 14 | 4 | |
Under Consideration | The "Authentication Required" prompt for secured layers in Collector maps is very clear and easy to read in the iOS v... by DavidSolari Occasional Contributor III 1 0 | 1 | 0 | |
Under Consideration | I would like the ability to have a field in a related table auto-populate based on a corresponding field in a parent ... by ChristopherBowering Occasional Contributor II 19 5 | 19 | 5 | |
Under Consideration | We have had issues dealing with multiple attachments for features in Collector. It would be useful if we could limit ... by EnvironmentalIntelligence New Contributor III 8 1 | 8 | 1 | |
Under Consideration | The ability of Collector to populate GNSS attribute fields for point data is awesome. It would be even more awesome i... by MichaelKnapp Occasional Contributor 17 1 | 17 | 1 | |
Under Consideration | Since more modern cars are coming with CarPlay and Android Auto support, I think it would be great to be able to get ... by JohnMDye Occasional Contributor III 11 3 | 11 | 3 | |
Under Consideration | Contingent Values in ArcGIS Pro helps data technicians in the office to efficiently manage the ensure the integrity o... by KyleWikstrom Occasional Contributor II 179 40 | 179 | 40 | |
Under Consideration | Not all data needs to be collected at the same accuracy. Current settings of Arc Collector restrict the GPS accuracy... by JessicaKirby2 New Contributor II 2 1 | 2 | 1 | |
Under Consideration | This idea relates to a discussion on Geonet (Editing experience in "new" ArcGIS Collector (iOS) ).I'm in the process ... by AnthonyCheesman1 Occasional Contributor II 35 1 | 35 | 1 | |
Under Consideration | I'd like to see a feature added to enable/allow maps with multiple copies of a layer to be downloaded and used offlin... by BrantCarman Occasional Contributor 60 8 | 60 | 8 | |
Under Consideration | When adding labeled points in the old Version and then zooming out, labels diappeared randomly. Even when zooming bac... by MichaelaSander New Contributor II 6 2 | 6 | 2 | |
Under Consideration | It would be great if there was the option to make attachments required for layers used in Collector. Thank you, by KatyHaddock New Contributor II 25 3 | 25 | 3 | |
Under Consideration | In Collector, when attaching photos to a feature collected in the field, no GPS EXIF data is recorded in the file on ... by JesseLutterman New Contributor III 270 20 | 270 | 20 | |
Under Consideration | Allow form controls/labels to be selected, grouped, moved, etc... together. by StaceMaples Occasional Contributor III 29 3 | 29 | 3 |
Idea Submission Guidelines
User | Count |
2 | |
1 | |
1 | |
1 |
