AGOL Z Value Popup Not Working
904
08-19-2020 12:14 PM
NeilWinn
I have z-enabled features in AGOL and used the Arcade Expression: Geometry($feature).z.  Two weeks ago this field was correctly showing up in the ArcGIS Online map and Collector.  I had made no changes to that web map or the features in it.  Now it won't work in either place.  I've tested this with multiple features including a newly created one.  Any thoughts on what changed?
RuiGe
by Esri Contributor
Hi, Neil,
"Now it won't work in either place. "
-- Do you mean the value of the field with Arcade expression not show up in the feature layer? Is it just blank?
NeilWinn
The value of the fields that populate is 0.00.  I have recently found that the values are more likely to populate with the correct z values in the web map and Collector if the map is saved using the Beta web map builder.
WilliamTrimble
Has there been any resolution on this @RuiGe ? Our organization is using the Geometry($feature).z in a popup and it functions with the same syntax in Pro and Collector but on Portal returns a value of 0.00.
AustinDoezema
New Contributor II
Same here. In fact, I was on the phone w/ tech support and they saw the same issue. But then it started working "magically", never got a straight answer as to what is going on. Having the same issue in other web maps as well.
