Bad Elf GPS for 30-pin Dock Connector not working in Collector
924
10-13-2016 04:48 PM
XingLee
New Contributor II
Hi all,
I'm trying to run an external GPS in Collector.
I have:
- iPad 2 running iOS 9.3.5
- Collector 10.4.0
- Bad Elf GPS BE-GPS-1000
In Collector, I have set the location receiver as the Bad Elf. On the iPad all location services have been switched on. In the Bad Elf app, I am able to see that the GPs is working and receiving satellite information but when I switch to collector it gives me the following error: 'No Information Received: Your receiver is connected but not sending information. Ensure your receiver is configured correctly'
any help would be appreciated. thanks.
Tags (1)
MiaogengZhang
Xing,
We don't officially support this 30 pin Bad elf GPS. But we support other Bad elf GPS listed at GPS receiver support—Collector for ArcGIS | ArcGIS . This 30 pin dock connector can still overrides location in integrated sensor. You can set "integrated receiver" in Collector as GPS Receivers to access it indirectly.
-Morgan
XingLee
New Contributor II
thanks, Morgan. I did do that and that's when I get that error.
