Hello Everyone,
I am trying to get a hosted feature layer view available for teams at my organization to use in their collector maps.
Once the view is in a map, if a user tries to take that map offline the process fails. According to the troubleshooting log, on this particular layer the error that comes up is JSON error 500: “Create Replica Internal Error” “Unable to create replica. Please check your parameters.”
I am using Collector App version 20.2.2 on Android and 20.2.4 on iOS, and published the layer from ArcPro 2.8.0. I am not aware of the version(s) that my colleagues are using, but I can replicate the issue on both versions above.
Details surrounding the map and layer:
-Was published to AGOL from Pro using the Publish Web Layer tool
-Point geometry, no geometry errors, (checked pre-publishing), points do not have Z or M enabled.
-Coordinate system is consistent with all other layers and views in Collector maps at company.
-Layer is configured for GNSS and Editor Tracking
-Layer has attachments enabled
-4 columns (not including the GNSS columns) have simple Domains (list of 2 values per domain) attached to them (but the error doesn’t mention domains as per https://community.esri.com/t5/arcgis-collector-questions/error-unable-to-create-replica-please-check... )
-OBJECTID and GlobalID are both visible columns in the layer
-No Feature or field filter on the layer
-Popup is configured to show all columns except GNSS and editor tracking columns
-Map and layer names only contain letters and underscores, no invalid characters present
-Collector maps do not contain multiple copies of the same layers
Troubleshooting I have already tried:
-un-checking the ‘Enable Offline Mode’ in the map, saving, making and saving and edit in the offending layer, then back to map settings to re-check ‘Enable Offline Mode’ and saving again
-add an attachment to the layer
-removing and re-adding the layer to maps
-deleting and republishing the layer and view to AGOL
Troubleshooting links I have already gone over, that are either not relevant to my particular details or all suggestions mentioned and tried did not solve my problem:
https://community.esri.com/t5/arcgis-collector-questions/collector-app-unable-to-create-replica-plea...
https://community.esri.com/t5/arcgis-collector-questions/arc-collector-unable-to-create-replica/m-p/...
https://support.esri.com/en/technical-article/000012535 (My data is not versioned, nor does my organization use our own Enterprise setup)
https://community.esri.com/t5/arcgis-collector-questions/map-download-failed-unable-to-create-replic...
https://community.esri.com/t5/arcgis-collector-questions/create-replica-failed/td-p/583262
https://community.esri.com/t5/arcgis-collector-questions/collector-unable-to-download-the-map/td-p/4...
Any help would be appreciated! Thanks in advance.
