Can I setup AGOL to view data only in Collector? If I first publish a feature service without any of the editing turned on (only query), I cannot get the Enable Offline checkbox to show up in the map. There is a weird trick someone found by which you change the basemap and then the Enable Offline checkbox shows up, however it's still not actually available in Collector. I have a work around but it's not a good one.
If I make the map first without coming from the data, and if the data doesn't have editing on, then the map will never be available in Collector even when you re-publish the data with all editing on. This is baffling.
