Is there a way to disperse coincident points in the Collector app?
821
02-23-2017 11:23 AM
HannesZiegler2
Occasional Contributor II
I have a geocoded hosted feature layer in ArcGIS online, but many of the points are coincident (they share the same address and thus the same XY location). Is there a way to disperse coincident points when they are selected in the collector app? I have searched Google but have not found a way.
Thank you!
by Anonymous User
Not applicable
Hannes,
If you are referring to points that are on top of each other, a list in collector should allow you to select the exact feature you want. You would have to disperse the points in ArcMap I believe before publishing. Collector does not have the functionality to disperse. You can move each point by selecting it and moving its location, but nothing automated.
