Is there a work around for not having wifi availbable IN the office to load maps and sync Collector data? Office does not have Wifi.
1368
05-22-2017 11:52 AM
BethanyCrenshaw
New Contributor II
The office I am working with has acquired some tablets and would like to collect field data and photos.  Wifi is not available at the office.  Is there a way to sync the maps and data without Wifi?
by Anonymous User
Not applicable
Bethany,
You should also be able to sync over cellular, but I would ensure that you have a strong cellular connection where you are located. Depending on how often and how much you sync, you will need to make sure that you have an adequate cellular plan that has enough data.
The setting for enabling map downloads and sync over cellular is located in the settings page for Collector under "Map Downloads and Sync". You can also enable "Push Only" under "Synchronization" as this will only push edits created by the user on that device and will not pull edits made from other colleagues.
Go offline—Collector for ArcGIS | ArcGIS
Dan
CarmelConnolly
Hi Bethany,
This blog post might help: Working with Collector for ArcGIS without syncing to ArcGIS Online or Portal for ArcGIS. — Esri UK
It uses ArcMap and syncs data locally, but you might be able to use the same workflow in ArcGIS Pro and sync data to your hosted feature service.
Carmel
