I'm trying to download a map in Collector that has one feature service that contains a point feature class and a related table.
I am using AGOL hosted feature services that I created from a file geodatabase in ArcGIS 10.3.1. For Collector, I'm using it on an iPhone with iOS 8.4.1.The map download seems to fail no matter the area I try to download, and I have checked for bad geometry using the Check Geometry geoprocessing tool and there aren't any issues there.
I have attached a screenshot of the error message which says "Unable to create replica. Please check you parameters. Exporting data for layer 1 failed."
I tried a suggestion from another post of going into the item details of the map and disabling the Offline Mode property, then re-enabling it, and re-sharing it with my appropriate user groups, but that did not fix my issue.
Kerry
