I'm trying to get as much of our internal tile cache onto Collector as possible.
We have a 1.2+TB tile cache which is built down to 1:1K.
BUT it's not built down to 1K everywhere. In some areas we only build down to 1:18K.
I've had previous success using Export Tile Cache from our physical tile cache into a TPK and using in Collector (90GB tpk file).
The reason it's only 90GB out of an original 1.2TB is the fact we're only building down 1K when there is high quality imagery.
But it seems to be hit and miss. Sometimes when I make these exports all they do is crash Collector.
Our tile caches are all Web Merc.
I don't want to use the standard procedure described in the doco Go offline since we have tile caches already built and to run them again for the extent we're talking about is ludicrous.
Are there some undocumented setting when using Export Tile Cache to TPK tool to make it work? e.g. it seems you can't just export an Area of Interest. You have to export the entire extent.
