Multi-Select dropdowns?
3223
06-07-2013 10:54 AM
JohnGillham
I've gotten dropdowns working through adding domains to the feature class I publish, but they only allow the user to choose one item (as you'd expect).  I have a need to allow users to select more than one option from a dropdown list (via a multi-select dropdown or a checkbox list), is this possible to do?  Any ideas or instructions greatly appreciated!
RussRoberts
Esri Notable Contributor
That is currently not supported in the app today. I would recommend adding this to ideas.arcgis.com and adding your requirements and use cases.
Russ
JohnGillham
Thanks Russ, I've gone ahead and added it for anyone wanting to help vote it up...  https://c.na9.visual.force.com/apex/ideaView?id=087E00000004gg7IAA
