Search for features ID in Collector for GIS
5206
02-24-2016 11:05 AM
RandallClark2
Occasional Contributor II
We work in an offline environment due to lack of WiFi coverage because of this we can not use the location services in Collector.
Most of the time this fine as we are collecting points or update features and it is easy to see them or navigate to them.
However on one up coming project we have more features, a lot more, and each feature has asset ID tag on.
So is there a way to set up collector so that i can search for features by id?
I know you can look up places but that does me no good.
Thanks
KyleBalke__GISP
Occasional Contributor III
Hey Randall,
Configure the feature search option to find locations by layer in your web map and use the ID field from your layer.  This will be honored in Collector and will allow you search by ID.
Configure feature search—ArcGIS Online Help | ArcGIS
TiffanySelvidge1
I have one of mine set up to search by account number...
I am using Portal and Collector
In Portal, go to the item details for the web map (the map not the app)
Click to edit the details
Scroll down to Properties and select the checkbox under Application Settings for 'Find Locations'
Select 'By Layer'
Specify the Layer, field and the condition
Save
You should then be able to search by file ID in Collector.
KyleBalke__GISP
Hey Randall,
