Garrett,
Yes, once I followed the above steps I was able to get the SP60 to work with Collector and Real-time VRS.
The Receiver selection is the confusing part as far as what setting to set for the GNSS Receiver - for now at least.
I was told that you have to use the "Integrated" selection for now with SP60 and SP80. Set the "SPace APP" to Mock Locations in your Android "Developer" settings. Be sure that you do not have "Location" turned on inside your Android device.
The only way really to know if the SP60 was giving me its accuracy via Real-time Accuracy was to look at "Accuracy Badge" and its details by click on that badge on the Map screen of Collector.
Also, inside of Collector, you can set an "Accuracy Threshold" so that you cannot collect worse than a certain horizontal accuracy. The Badge will be RED and will not let you collect anything about the accuracy you set.
I did speak with some of the Spectra Precision staff at the Esri UC in July and they said they are currently in communication with Esri staff to get the SDK between the SPace app and Esri Collector set up. Not sure when this will be completed. This should then solve the Bluetooth GNSS Receiver selection and the ability to write GNSS Metadata from the SP60 and SP80.
Stay tuned......
Jay
