Hi everyone,
Is it possible to switch between the map that you have downloaded and the original map that is online?? When you're out in the field you might not have signal the whole time. But when you have a signal, it would be great to just switch over to the online map, where you can zoom in closer and so on. But I seem to have problems figuring out how to do it, if it is even possible, when you have downloaded the map.
If I log into my account, I'm only able to see the downloaded map, and not the online map... I could of course just remove the downloaded map, but if I then loose signal, I'm in a world of trouble again.. 🙂
Any thoughts?
/Lars
