Yes, that seems to have gotten me to the correct spot.
So within this window of code, I am to delete the word “sync” from the following line of code. I find two instances of this piece of code within the Update Service Definition window.
"capabilities" : "Create,Delete,Query,Update,Editing,Sync",
Once I delete those two instances, I hit the Update Service Definition button I assume. After I did that I went back to the same URL as below to add the word “sync” back in. But, the word “sync” is already back in the code as if it wasn’t deleted. It doesn’t seem like anything occurred.
http://services.arcgis.com/I6MwRSmdA9fof9PW/arcgis/rest/admin/services/REPAIR/FeatureServer/updateDefinition<https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fservices.arcgis.com%2FI6MwRSmdA9fof9PW%2Farcgis%2Frest%2Fadmin%2Fservices%2FREPAIR%2FFeatureServer%2FupdateDefinition>
Update Service Definition - REPAIR
Note: This operation is only supported via POST
Update Service Definition:
ASync:
True False
Format:
Travis Anderson
