Update Failed - Geometry could not be set
7030
06-12-2015 01:10 PM
RobbHodges
I am trying to update 2 fields in a manhole feature class, which is part of a geometric network. I am able to start an editing session in Collector, change the values of those 2 fields, but when I go to submit, I get
Update Failed
     Unable to complete operation
     geometry could not be set
Any ideas?
MarianneFarretta
Hi Robb!  Take a look at this documentation, it may apply to your situation: Author feature services—Documentation (10.3 and 10.3.1) | ArcGIS for Server
"If you allow edits on the feature service and the feature service contains feature classes that participate in a geometric network, the feature class data must be in the same projection and coordinate reference system used by the editing client application. "
MarianneFarretta
charbelhawchab
Hello @MarianneFarretta ,
I am receiving on my field map phone app the same message : Unable to complete operation. Geometry could not be set.
What should i do?
The terms  "projection and coordinate reference system used by the editing client application. " means settings on the phone where the app is used?
