Using an external GNSS receiver with iPad
4193
12-09-2014 08:12 AM
DylanJones
Is Collector for ArcGIS capable of using an external GNSS receiver connected to an iPad to obtain more accurate results?
JoeFlannery
Occasional Contributor III
I have successfully connected a Garmin GLO via bluetooth to an iPad.  It worked great.
DanielEstrada
New Contributor II
Yes, there are several products available. I use the Bad Elf GNSS Surveyor with 1 m accuracy. There are others that can serve your needs out there a google search can get you on the right track.
