ArcGIS Dashboards Questions
188
12.4M
2.6K
Under Consideration | In ArcGIS Dashboard on some of the elements you can activate the funktion "Summarized data download". This can be use... by AnnelieSköld New Contributor III 1 1 | 1 | 1 | |
Under Consideration | I’m hoping there could be an advancement to the Dashboard Serial Chart widget to add the ability to show a legend at ... by EllieLinden New Contributor II 0 1 | 0 | 1 | |
Under Consideration | Either allow the user to change the zoom scale when filtering by grouped values, or update the default to better acco... by KristaGobeille New Contributor II 3 1 | 3 | 1 | |
Under Consideration | We are loving the introduction of Tables in ArcGIS Dashboards. It would be great if the table element could have its ... by EmilyMcLeanACTGOV Occasional Contributor 31 7 | 31 | 7 | |
Under Consideration | Hi All,In dashboards when you enable selections for multiple, in order to return to home and not have any list items ... by GIS_Fox Occasional Contributor III 12 4 | 12 | 4 | |
Under Consideration | The ability to invert the Y axis of a serial chart to allow, for example, river level sensor data to be shown as you'... by JonathanMcDougall Occasional Contributor III 12 8 | 12 | 8 | |
Under Consideration | So during this years Esri User Conference I learned about Data Clocks, I was wondering if data clocks and Heat Calend... by RachelStevenson New Contributor II 13 2 | 13 | 2 | |
Under Consideration | Currently there is only the ability to add a guide on the y-axis. Like this:However, amid COVID-19 we need the abilit... by Mandalorian New Contributor III 13 1 | 13 | 1 | |
Under Consideration | Now some elements in a dashboard can use Arcade, the ability to determine how many features in a map layer or list wo... by MarkPainter New Contributor II 0 2 | 0 | 2 | |
Under Consideration | I want to group my data by week in serial charts. Currently, the only options are: second, minute, hour, day, month, ... by AdaLi1 New Contributor III 28 7 | 28 | 7 | |
Under Consideration | Ability to customize the look of serial chart pop-ups in CSS and add additional fields to pop-ups by NataleeDesotell New Contributor III 9 1 | 9 | 1 | |
Under Consideration | Scenario 1:You have a simple statewide, county based, choropleth map. You need to display it at its full extent and... by AdamRepsher Occasional Contributor III 36 7 | 36 | 7 | |
Under Consideration | It would be very useful for the Date Selector Widget in Operations Dashboard to filter using multiple attributes as i... by SamanthaGriffore Occasional Contributor 4 3 | 4 | 3 | |
Under Consideration | When an operations dashboard that contains a map is embedded in a web page or sites page, the scrolling function of t... by JessicaNeuner1 New Contributor II 2 2 | 2 | 2 | |
Under Consideration | Real-world Problem: Users want to share the extent of the map/dashboard they are looking at, with other non-GIS staff... by PaulDoherty2 Occasional Contributor III 13 3 | 13 | 3 |
Idea Submission Guidelines
User | Count |
5 | |
4 | |
4 | |
3 | |
3 |
