We've created a SQL view from SQL MGMT Studio, and published to an Enterprise geodatabase. This visualizes fine, and we can successfully publish to Portal/AGOL without a problem. Within Portal/AGOL, we can see the data table and visualize both the map image layer and feature layer versions of the view.
We encounter an issue when attempting to visualize the Feature layer version of the view within a Dashboard. The feature layer view will not display points within the dashboard (even though it works in a web map). But the map image layer displays those same points just fine. We also created an indicator that accurately picked up the total number of points within the map extent, even though there were no points visible.
Any input on why the feature layer version of the view will not display in a dashboard?
