We have a Dashboard that presents a map and indicators that summarise the hectares within the current map extent for each type of feature. The indicators are filtered by using the map extent filter (and attribute filtering).
When the Dashboard first loads, it briefly shows values in the indicators before switching to the 'no data' messages. Changing the map extent gets the indicators to present values again, and it works fine after that.
My question is, is there anything I can do or check to fix this no data issue? If not, where can I log an issue/bug?
Link to Dashboard: https://www.arcgis.com/apps/dashboards/f6dd44763f0b476e8a1c2f0504fc8779
Video demonstration also attached.
