Hey there Eric...
So its been a year but if you haven't figured this out already here's teh solution:
C:\Users\<user>\AppData\Local\Apps\2.0\8ZDDVWNR.GX5\8CQ7GB4J.0YN\oper...app_f464941b06bea132_000a.0001_ae4f295654969edc
(The rest of the location path after "C:\Users\<user>\AppData\Local\Apps\2.0" might be different in your case as that is variable, but it will look similar and when you arrive at the location you will see a lot many files making it difficult to realize which file you have to edit, so in the search box for the folder type in 'exe.config' it should display few xml files.)
Open the one that says operationsdashboard.exe, edit the file in notepad and look for a tag <appSettings> , now after the tag <appSettings> add this tag into the file :
<add key="useAcceleratedDisplay" value="false" />
Now save the file and try executing Operations Dashboard, it should work.
Hope this helps!
