Hi Derek,
Yes im using layers in a webmap reading from a feature service.
if i open this feature class in ArcMap it is normal that the correct values are showing and not the coded values.
however in the webmap, in the popup and in the attribute table, it is showing numbers instead.
should i do anything in arcmap or in webmap to avoid this?
Thank you for your help.
