I have sanitary manholes that I have created two layers from. One layer is symbolized based off of a condition, the second layer is symbolized based off of repair status. I have no filters on my layers in my web map. I would like to create a Pie Chart showing the percentage of manholes that have a certain condition.
My manholes total 1355 and my condition value counts should be:
1265 manholes have 0-Not Evaluated
11 manholes have 1-Eventually Needs Maintenance
1 manhole has1.5-Eventually Needs Maintenance
11 manholes have 2-Needs Maintenance
1 manhole has 2.5-Needs Maintenance
66 manholes have 3-Maintenance Past Due
However, in Operations dashboard when I create either a pie chart or a bar chart for manhole condition, my counts are:
926 manholes have 0-Not Evaluated
10 manholes have 1-Eventually Needs Maintenance
10 manholes have 2-Needs Maintenance
52 manholes have 3-Maintenance Past Due
It appears to me that the pie chart and bar chart are performing some kind of filter. The Summerize Widget does show the correct count.
Each of my manhole conditions layer and my manhole repair status layers are part of a map service, however, they are referenced in my web map as individual feature layers.
Why are my totals off when I use a pie or bar chart?
Thanks!
