Pop-ups not working in dashboard
2745
11
03-24-2022 03:47 AM
DarraghOSullivan
Hi all,
Pop-ups in our dashboards are no longer working - no error message or anything, nothing happens when clicking the feaure. The underlying Web Mapa are working fine, with pop-ups showing in the Map Viewer.
I've tried in Chrome and Edge but similar results.
Any ideas, thank you?
DarraghOSullivan
Ours seem to be back working again today. Maybe a bug was fixed or something?
JayantaPoddar
Are you using a Map Service for the layer for pop-up?
Try using a Feature Service or a Hosted Feature Layer instead, and let us know if it works.
Think Location
DarraghOSullivan
Thank you @JayantaPoddar . Yes the dashboard uses a Hosted Feature Layer already. Should have said it's all in AGOL.
jcarlson
Your dashboard's map widget can have a setting to suppress popups. Can you confirm that popups are enabled on the widget?
- Josh Carlson
Kendall County GIS
DarraghOSullivan
Thank you @jcarlson . Yes I can confirm that the popups are enabled in all widgets.
AlessioDiLorenzo
Same issue for us.
Nothing changes if the layer comes from arcgis server mapservice, arcgis server feature service or agol hosted feature service. We tried all of these
DarraghOSullivan
AlessioDiLorenzo
Ours continue not working for now
SandraLuken1
Hi Yes, this should be resolved now. Can you confirm that the pop-up is also not showing in the map viewer as well as dashboards?  Is there is an example that can be provided, or can work with Esri technical support to reproduce the issue.
AlessioDiLorenzo
Hi @SandraLuken1,
pop-ups are working now.
Thank you.
