Data Reviewer Speed
6946
11
04-01-2015 02:28 PM
AnthonyBarron
New Contributor III
This is a multi-part question and I am hoping someone may be able to point me in the right direction. I am working with Data Reviewer 10.2 and I have a Batch Job consisting of Table To Table, Geometry on Geometry, Duplicate Geometry, and Execute SQL checks. The Batch File checks for errors in ~ 375,000 points and ~58,000 Points. My concern is the amount of time required to run the batch file. I'm running my test now and it's been 8 hours with only 209,000 points validated.
My questions are as follows:
1) How can I expedite the batch file?
2) If I run the batch file against "Changed Features Only" will it speed up the results? If so, how does Data Reviewer determine which features have been "Changed"?
SteveSalas
Michelle - just saw this new patch:  Esri Support 10.4.1
Are there any metrics you can share about how much of an improvement this makes?
JonahWaterman
New Contributor III
Try and create table index, this will expedite the process. I index all of my tables before batches are run. Hope this helps
