After some further testing, I found out that I get different results for exactly the same check when I run the check separately (Run data check) and when I run the check as part of batch job (Batch validate on toolbar or GP tool Execute reviewer batch job).
The first option (single check) gives the expected results: Lines of FC A that do not intersect (in the form of a line) with lines of FC B and are not within FC C. This gives the first 2 results in the print screen below.
The second option (the same check, but now as part of batch job) gives a different result: the 2 results mentioned above and 7 other results, which seem to be related only to the second part of the composite check (FC A not within FC C). These 7 results are visible in the REVTABLEMAIN and somehow also have a separate CHECKRUNID, but this check is not included in the REVCHECKRUNTABLE.
I expect it has somehting to do with the workspaces of the feature classes. FC A and B are in a separate file geodatabase, while FC C is in another enterprise geodatabase.
Does anyone know if this is normal behaviour and/or how I can run this check as part of a batch job and still get the right result?
Thank you!
