SQL Check can't access SDE SHAPE.LEN field
4049
5
11-15-2010 08:55 AM
GregHorch
I'm building a SQL check that compares a manually entered length to the Shape.Len.  This works fine in a file gdb but when the workspace is in SDE, I can no longer access the Shape Length field.  Am I missing something or is this a limitation of PLTS?
MichelleJohnson
Thank you for bringing this to our attention.  I have logged a defect for this.
Bug ID: 4451
Name: Execute SQL query builder does not l ist the SHAPE.LEN field for SDE geodatabases.
At this time the status of Bug ID : 4451 is "New". The tentative planned fix version has not yet been determined.
GregHorch
thank you. my issue is 9.3.1 sp2.  is this a bug in 10 as well?
MichelleJohnson
Yes, it is.
MichelleJohnson
A patch for PLTS 9.3.1 Service Pack 2 has been released that addresses this issue.  The patch can be found here.
GregHorch
Excellent.
