Hello,
I upgraded from ArcGIS 10.3.1 to ArcGIS 10.4. I'm having a problem with ArcGIS for Desktop
Background Geoprocessing installation. The setup wizard looks for setup files under the following location:
C:\Users\Saygins\Documents\ArcGIS 10.3.1\DesktopBackgroundGP\SetupFiles
However, the setup files are in D:\esri\BackgroundGP\DesktopBackgroundGP. I changed the path
and tried to continue but ended up with no luck. The last error message I got said "The D:\esri\BackgroundGP\DesktopBackgroundGP\SetupFiles\setup.msi was not a valid installation package for the product."
Please note that I uninstalled ArcGIS 10.3.1 prior to installation of ArcGIS 10.4. Have anyone encountered
such issue before ? It'd be great if you could kindly share your suggestions. Thank you.
