Check Customize Extensions to ensure that the extension is toggled on.
By chance that toolbar could be offscreen and you will have to search for it. If you use a dual monitor, the fix is easy. otherwise you might have to try the alt tab thing or look around the edges for it. Short of that renaming your Normal.mxt template in your profile might bring it back.
