When importing control points in Drone2Map from txt-file the first point is always removed and not imported. I've shuffled the point rows around in the txt and it is not something wrong with that point, D2M just removes the first one regardless. Is this expected or a bug in 2023.1?
You would need a first line describing the columns. Four (4) different characters can be used as delimiter (Semicolon, Comma, Pipe, Tab). An yes i normally do
PNTID;X;Y;Z
01;577559.9836;6620482.6793;126.1027
02;577565.8906;6620494.5779;126.6658
Hi @JEngvall I have never experienced what you are describing. How does the text-file look like? I normally have files looking like:
PNTID;X;Y;Z
Do they look like this:
"01;577559.9836;6620482.6793;126.1027
02;577565.8906;6620494.5779;126.6658"
or like this:
"PNTID;X;Y;Z
My guess is that if you only have:
then the first row will be removed. But then I guess D2M uses the first row as template for the control points and that the behavior is excepted.
PNTID;X;Y;Z
that solves my question, thanks!
