Offer recommended system configurations on Virtual Machines
627
04-01-2010 09:36 PM
Status: Implemented
RajendraDutt
New Contributor III
This could be a great way for ESRI to showcase and allow clients to test their internal configurations against ESRI's recommended optimized systems.   In enterprise arena system performance has been the sore point for supporters of ArcGIS Server.  Optimized virtual machines with recommended configurations would allow them to play against a working solution.
5 Comments
CarlosColón-Maldonado
Totally agree, especially using the latest ArcGIS Runtime SDK for Java (Linux) in a development environment. The rumor is that some have failed and some suceeded at tweaking VMs get it to work.
EsriAGSIdeas
There is currently a document on how to configure ArcGIS Server using VM Ware and it can be found here:
http://www.vmware.com/resources/techresources/10091
DEWright_CA
The problem with relying on documents with recommended specs is that its very subjective; different use cases mean the specs of a machine can change.
jill_es
The following tech papers address ArcGIS Enterprise system recommendations:
For organization-specific recommendations, consider working with Professional Services or our business partners.
