That looks like a good workaround for your situation, Elliot, about as good as you could get. If I had to use 10 I'd probably try it. But like the workarounds I've tried with the DDP such as using a table to pan around to different pages, it can't fix all the problems even skipping the initial setup work. You certainly wouldn't want to open up any other tables in that project because in 10 (unlike 9x) they would all open up in that narrow window. It also requires dropping the mouse and typing in a number for a single page, or more for multiple pages, and if the latter it doesn't persist. Now if in SP1 they allowed tables to appear in their own window, and in the DDP allowed the use of an index table set up like yours with just clicking in it to move the map to different pages or export one or more, then I'd like that.
