Thanks Derrick. Yes new VM going to different machine name and IP. I believe portal and server web adaptar name should be same as old one. Is there any other parameter should match? or do I need to take into consideration?.
Does portal and server import /export option help? I remember long back, portal is closely tied to machine name. if you export dump and import on machine with different name will fail. Any thoughts?
I am trying jolt down all steps and process for this migration.
Anyway thanks again for quick response.
