Hi. Has anyone else successfully got Portal going using the latest 10.3.1 server AMI on Amazon Web Services?
I have created a server using this AMI, which comes with Portal pre-installed. The documentation (link below) says to go to the following address to set up the initial administrator account:
https://<fully qualified machine name>:7443/arcgis/home
This address just comes up in the browser as 'This webpage not available, ERR_CONNECTION_REFUSED'.
I have tried using the ip address, computer name, AWS public name, and a public domain name that I have created (and that has the SSL cert bound to). None of these get to the portal page.
Going to https://localhost/portal or substituting the AWS public name or the public domain name for 'localhost' all redirect to the webadaptor configuration page which is https://localhost/portal/webadaptor but of course I can't configure the web adaptor without first setting an initial administrator account.
I am following the documentation at http://server.arcgis.com/en/portal/latest/administer/windows/deploy-portal-on-aws.htm
Any ideas?
Cheers,
-Paul
