I am having difficulty adding specific external services to my installation of Portal. Any insight would be greatly appreciated.
Attempting to add http://geo.weather.gc.ca/geomet/?lang=E&SERVICE=WMS&REQUEST=GetCapabilities
either as an item or directly to the map produces this error:
"Service '' does not exist or is inaccessible."
The following GeoRSS (http://www.geonet.org.nz/quakes/services/all.rss) produces this:
"The GeoRSS, http://www.geonet.org.nz/quakes/services/all.rss, cannot be added to the map. It is either not available or you have entered an invalid URL for the type of layer you want to reference."
These are just two examples of the many I am encountering. I cant seem to find a pattern to which ones work and which do not. I've confirmed these services are working by successfully adding them to AGOL.
Diving a bit deeper, I find that the portal logs claim that the connections are timing out.
Sep 30, 2014 12:52:24 PM com.esri.gw.proxy.ProxyServlet service
SEVERE: Proxying request to: http://geo.weather.gc.ca/geomet/?lang=E&SERVICE=WMS&REQUEST=GetCapabilities failed: Connection timed out: connect
Sep 30, 2014 12:57:07 PM com.esri.gw.proxy.ProxyServlet service
Sep 30, 2014 1:19:00 PM com.esri.gw.proxy.ProxyServlet service
Sep 30, 2014 1:22:53 PM com.esri.gw.proxy.ProxyServlet service
Sep 30, 2014 1:33:06 PM com.esri.gw.proxy.ProxyServlet service
Sep 30, 2014 2:17:32 PM com.esri.gw.proxy.ProxyServlet service
SEVERE: Proxying request to: http://www.geonet.org.nz/quakes/services/all.rss?SERVICE=WMS&REQUEST=GetCapabilities failed: Connection timed out: connect
Sep 30, 2014 2:18:36 PM com.esri.gw.proxy.ProxyServlet service
Sep 30, 2014 2:25:36 PM com.esri.gw.proxy.ProxyServlet service
Any ideas?
By the way, My Portal and Server are 10.2.2
