Exporting a webmap from ArcGIS Online
1087
08-22-2016 03:07 PM
MarcusHarner
Does anyone know how to export a web map from ArcGIS online (into some file format), so that it can be imported into Portal?
PaulDavidson1
There is also the Esri ArcGIS Online Assistant that will probably do this:
https://ago-assistant.esri.com/
pretty sure this will do it for you.
Or you can script it:
http://server.arcgis.com/en/portal/latest/administer/windows/example-copy-content.htm
Or the geo-jobe tools probably will do this:
http://www.geo-jobe.com/admin-tools/
PaulDavidson1
MarcusHarner
Thanks Paul!
