I've recently installed Portal for ArcGIS 10.3 and federated my ArcGIS Server services with it. I've shared all of my map services, my web map application and allowed anonymous access to Portal, however, when I load my JavaScript application I am still being redirected to a log in prompt for Portal. Can anyone suggest a possible reason why? I don't want users to have to log in at the moment to access the application. Could it be to do with ArcGIS Server system tools?
Thanks.
Looks as though I had a few services that I hadn't changed permissions for so that has kind of solved the problem. However, another issue is that if I want to use Windows Authentication for Portal, but still want to allow users to access my application without logging in (and they are not registered as a user in Portal), this doesn't seem to be possible because Anonymous Authentication is disabled. Is there anyway around this?
Message was edited by: Stephen King
