Hi everyone,
I am having a huge headache with my Portal. I hope you can help me in finding a solution.
I've installed Portal for ArcGIS Server 10.4 (Windows) and the portal is working very well with http, but not with https.
What I did so far (according to this instruction: http://server.arcgis.com/en/web-adaptor/latest/install/iis/enable-https-on-your-web-server-server-.h...😞
If I click “Advanced” > "Go on to https://webadaptor.domain.com/ (unsecure)", I see the sign in mask, but:
I’ve cleared the browser cache multiple times. Is there a Portal cache that needs clearing?
Here are settings from Portal’s Security Settings:
"Allow Access to the Portal through https only" is checked
"Allow anonymus access to your portal" is unchecked
And from the Portal Administrator Directory (Home > System > Web Adaptor):
The ports used by Portal are allowed (see Ports used by Portal for ArcGIS—Portal for ArcGIS (10.5) | ArcGIS Enterprise )
To sum up, I don't know why https is unsafe. Who can help me solving this problem ?
Any help is highly appreciated. Thanks in advance!
Regards,
TimBuktu
