Hello All,
I am trying to set up Portal to accept both Active Directory and Portal Authentication users. The problem occurs when I try to log in as a Portal user. I can't do it. I am logged into my machine through Active Directory, but when I browse to the portal homepage, I have no option to log out. I can't get an interface to log in.
I am afraid that there will be an OR in this statement:
You either set up an Active Directory, automatic login environment, OR, an Active Directory/Portal Authenticated set up where you must manually sign in every time with your credentials.
Am I correct, or is there a special way to set up a way to log in with a Portal Authenticated User while set up for AD auto-login?
Thank you,
--Adam
