@Department_of_Communications__ you could mark @MaxBöcke answer as correct answer as I think he gave the right Apache configuration file syntax to avoid stacked headers and coma separated values for redirect_uri.
Apologies ... an oversight the solution provided by Max was correct, slightly different for our environment but definitely the correct solution. with the joy of a solution I forgot to say thanks, so many thanks and happy posting
Paulg
