survey123 directoy through our portal and enterprise gdb?
551
02-16-2017 10:21 AM
JeffreyWeaver
are we able to access the data stored in survey123 directoy through our portal and enterprise gdb without having to script out an etl process?
DerekLaw
Esri Esteemed Contributor
Hi Jeffrey,
Survey123 for ArcGIS data is stored in Portal for ArcGIS behind-the-scenes as feature services. The feature service "lives" in the associated GIS Server that acts as the hosting server for Portal, and the actual feature data "lives" in the ArcGIS Data Store (not in an enterprise geodatabase).
So you could simply navigate to the survey's feature layer Item Details page > Overview tab and click Export Data.
Hope this helps,
