unable to create the group at this time
3952
15
11-09-2016 10:48 PM
OfraAinemer
Hello,
I've installed portal for ArcGIS 10.4.1 on a new server, with web adaptor and CA certificate.
While I'm trying to add a group, I get this message "unable to create the group at this time".
Any ideas?
Thanks
Ofra
JayantaPoddar
MVP Esteemed Contributor
A known bug
  • BUG-000099447 - Unable to upload files or create groups in the Portal home application after updating the browser to Firefox 49, Chrome 54, or Safari 10.
Use this patch Portal for ArcGIS Home Application Upload Patch
Think Location
JayantaPoddar
A known bug
Think Location
NadineTrahan1
New Contributor III
I'm having trouble with the patch suggested, is there a patch for the patch?
JayantaPoddar
Make sure you install the appropriate version of patch. Are you using Portal for ArcGIS 10.4.1?
Think Location
NadineTrahan1
New Contributor III
Yes I am. For now I worked around by using Internet Explorer to create a group, but it would be nice for our users to be able to create their own. I've tried it on two separate Windows 7 machines, same result. Any ideas?
Thanks
NadineTrahan1
New Contributor III
Should I be installing this on the user or server machine?
JayantaPoddar
The one where Portal for ArcGIS is installed.
Think Location
NadineTrahan1
New Contributor III
Ok well I was able to successfully install on portal machine, which is the server, but even after closing and reopening Chrome, logging out and into portal, I get the same error message.
NadineTrahan1
New Contributor III
Jayanta since there is a work around, I will create all the user groups with Internet Explorer, as there much bigger issues I need to move onto. Thanks anyway for your help.
JennieCatalano1
New Contributor III
I'm having the same issue.  We're running 10.4.1, I'm running Chrome 55, installed the above patch and still can't add groups.
