Wrong FullExtent in Layer with scaled visibility
875
10-18-2011 04:54 AM
IvanIvanov3
Hi!
I have layer:
Min. Scale: 20000
Max. Scale: 0
Default Visibility: True
XMin: 65125.1001000004
YMin: 61834.4901999999
XMax: 136886.8202
YMax: 128341.3102
Spatial Reference: PROJCS["m64_1",GEOGCS["GCS_Pulkovo_1942",DATUM["D_Pulkovo_1942",SPHEROID["Krasovsky_1940",6378245.0,298.3]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",95942.17],PARAMETER["False_Northing",-6552810.0],PARAMETER["Central_Meridian",30.0],PARAMETER["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
When i'm trying to zoom on this layer's extent it's returns other extent values and zoom goes wrong.
it returns following extent:
Xmax: 84464.640100000426
Xmin: 65125.100100000389
Ymax: 128273.57019999996
Ymin: 120906.50019999966
this happens only with this layer. Other layers don't have "Min Scale" value and zoom is good.
Any ideas why could this happend?
Thanks!
IvanIvanov3
solved this by casting Layer to FeatureLayer and used FeatureLayer.LayerInfo.Extent. it returns valid values
