10.2 - Accessing ArcGIS Server Manager
3651
08-09-2013 09:53 AM
JacobRaymond
New Contributor III
I am running a multiple machine setup and haved recently upgraded to 10.2.  After a reboot of one of my machines last night I can no longer access ArcGIS Server Manager (http://server:6080/arcgis/manager) on that machine.  The other machines are accessible through that link.
This is the error message I now get:
[ATTACH=CONFIG]26617[/ATTACH]
Has anyone seen this message when trying to access ArcGIS Server Manager?
BrettElliot
New Contributor III
How strange...
I'm getting the same error.  Let me know what you find out.
[ATTACH=CONFIG]26618[/ATTACH]
AlexeyTereshenkov
Regular Contributor III
Are you sure you enter http://walte:6080/arcgis/manager/ as your URL? It seems as you have Portal for ArcGIS extension installed and you are trying to login into the Portal (the Portal login page is http://walte:6080/arcgis).
ChrisHanobeck
We are having the same issue.  When we go to upgrade to 10.2 it asks for the arcgis account password, which I have no clue what it is.  So I changed it and it screws everything up.
We tried creating a test instance, and it keeps saying we are not authorized once we finish the 10.2 upgrade.
JacobRaymond
New Contributor III
We did not have portal installed.  I don't know what caused the problem but wiping that particular machine and reinstalling ArcGIS server seemed to fix the problem.  It was only happening on the one machine of our multi-machine setup.
Thanks for your suggestion though.
