ArcGIS 10.5 enterprise on Windows Server 2016
5127
17
02-26-2017 11:36 PM
ImtiyazPasha1
Can we install ArcGIS 10.5 enterprise on Windows Server 2016?
RandallWilliams
Is there a Windows Server 2014? There's a SQL Server 2014, but I didn't think there was a Windows Server 2014 and maybe SBS 2014?
RebeccaStrauch__GISP
My apologies....I was thinking SQL.   Wasn't reading it close enough.
...and to add, our IT spins up our machines these days, so I clearly don't know what Server OS's they are using these days.
MichaelVolz
Esteemed Contributor
Damiano:
Do you have the ability to spin-up a 2016 server(s) and load the 10.5 software to create a development environment that you could use to test yourself if your business needs are currently met with this architectural setup without significant bugs?  You could do this testing while your production environment stays as is.  10.5.1 should be out within 2 months according to ESRI so you could always upgrade your new 2016 servers at that point if you encounter significant bugs with 10.5.
DamianoMontrasio
Thanks Michael,
I think it's the best way...
deleted-user-K4WEem421GEH
Wholeheartedly agree with you montrad
for those only looking at the graphic above, I'll add what the * refers to:
*If you configure the ArcGIS Server site as the hosting server for an ArcGIS Enterprise deployment, enable SSL 3.0 in the Internet options to allow users to publish hosted scene layers. See Esri technical article 000016013 for more information.
RandallWilliams
This will be addressed in 10.6.
Note that the requirement is not to enable SSLv3 on Windows 2016 globally or for the Web Server role - rather the requirement is to enable SSLv3 for the ArcGIS Server account only, which governs how Windows uses SSL as a CLIENT. Client support for SSLv3 is disabled by default in Windows 2016.
SSLv3 is only required for communication between the ArcGIS Server and the ArcGIS Data Store and when publishing Hosted Scene Layers.
